hkturbo Posted October 21, 2011 Posted October 21, 2011 i know this is a common problem on toyotas.. basically its the first initial press down on the pedal which is stiff and then its fine. but that stiff push is so annoying as it burns the clutch and gives a shit drive. I've wd40'd the throttle but still not luck. Quote
Asad Posted October 21, 2011 Posted October 21, 2011 Didnt know it was common ^take the cable off the throttle body and spray some wd40 down the cable inbetween the sheath and metal wire youll need a straw for the wd40 Quote
hkturbo Posted October 21, 2011 Author Posted October 21, 2011 well my mates got same prob on his paseo and corolla.. I've sprayed the throttle cable and the metal spring thing.. il try loosenin bolt. Quote
hill_bill10 Posted October 25, 2011 Posted October 25, 2011 mine has the same issue, its not the cable, its the throttle body, its the butterfly sticking.try taking off your tb and giving it a really good clean with some brake cleaner. Quote
corofin12345 Posted October 25, 2011 Posted October 25, 2011 dont mess with the pully stops,nuts etc on the throttle body, move the pully by hand to see if its stiff, take off cable if needs be.. id say its the butterfly as said above.. check the cabe too once its disconnected from the pully, use the pedal to push in and out Quote
