Max9650 Posted October 22, 2011 Posted October 22, 2011 Hey. So i just have a couple of problems with the Gt atm! ( minor )1. I had an idleing problem so i turned the idleing screw,under the rubber bung - ontop of the inlet manifold ( just under the strut ) and it seems to be fixed, im just wondering is that definetly the idleing screw not the mixture!?2. When changing the Fuel filter i noticed that there was a little circuit board just attacted to the passangers side strut housing, one hose goes to the FPR and one goes to the inlet manifold, does anyone know what this is ? problem is abit of the circuit board has burned out so im wondering if thats causeing any problems3. When i redline the car, it sounds like its redlining at about 5.5k / 6k revs, is this normal? 4. When im in 2nd / 3rd gear when i push the accelerator just genly at lowish revs, it sounds like there is an air leak, but i dont think there is, is it just the turbo spooling? or is it normal?This is my first turbo so i dont know much lolAny help with any answers would be great! Sorry there not very detailed,Thanks ps : it's a gt turbo with standard turbo, decat , FMIC , HKS Actuator ,0.8bar Quote
Max9650 Posted October 22, 2011 Author Posted October 22, 2011 Maybe i should have done seperate topics lol Quote
Simon Posted October 22, 2011 Posted October 22, 2011 Can you get some pics of the circuit board might be able to help then if we can tell whet it is.You will hear the turbo spooling will hear it more if your not funning the stock air filter. Quote
Asad Posted October 22, 2011 Posted October 22, 2011 1) turning the idle screw usually just masks the problem.....how does she drive? miss fire? clean out the throttle body? idle control valve?2) you got any pictures of it mate? how many wires? colour?3) iirc the ct9 runs out of puff at high revs anyway....but the rev limit is 6-7 iirc but i wouldnt be taking it that far anyway mabe its fuelcut?4) could be an air leak......do you have a boost gauge? whats it reading when you hear the air leak? check all your hoses and clips Quote
Max9650 Posted October 22, 2011 Author Posted October 22, 2011 It seems to drive okay, i thought it used to redline alot easier, im going to get a fuel pressure test done at college after half term ,just abit worried if its running lean as thats not good i've cleaned out the ICV and recently gave it a new fuel filter my tutor had a look who has been a mechanic for years and said its running like a dream ( sound wise ) so i doubt its a misfire, I will try and get a picture tomorrow of the ciruit board, its literally right next to the tophat Quote
Max9650 Posted October 23, 2011 Author Posted October 23, 2011 **PICS**So finally managed to get some pictures, its not great pics but it may helpit's taped up now cause the case that the circuit board is splitit has a hose that goes to my FPR Also this is my Turbo timer, it has a setting called A/F , Is this my air / fuel ratio? Quote
Simon Posted October 23, 2011 Posted October 23, 2011 That sensor i think is for you AVCR it's a boost sensor for something aftermarket either the AVCR or a boost gauge Quote
Max9650 Posted October 23, 2011 Author Posted October 23, 2011 the avcr isnt wired up to make it show the boost, but you can adjust it, the boost gauge is wired up thats what ive been told Quote
