rabbit1234 Posted October 23, 2011 Share Posted October 23, 2011 hi everyone,think i sould get down to the problem.rite im basicaly in the middle of an engine rebuild and im fitting a thicker head gasket, regrinding the crank the full shabang.the problem i got is the head bolts.i want to uprate the head bolts but dont want to tap and die the block and heads and dont want to spend stupid money.can you suggest what head bolts and where i can get them from (website would be easyer).or would i be better off getting standard toyota head bolts bearing in mind im going to be running high ish boostage.any advise would be greatfulthanks Quote Link to post Share on other sites
Ryan-11 Posted October 23, 2011 Share Posted October 23, 2011 4e arp headbolts, no need for drilling and re tapping, normally around £110 £120 Quote Link to post Share on other sites
rabbit1234 Posted October 23, 2011 Author Share Posted October 23, 2011 where can i get them from mate? Quote Link to post Share on other sites
Ryan-11 Posted October 23, 2011 Share Posted October 23, 2011 i got mine from east coast customs over on tgtt. geo (enzo) on here can prob get them for u. Quote Link to post Share on other sites
rabbit1234 Posted October 23, 2011 Author Share Posted October 23, 2011 thanks mate Quote Link to post Share on other sites
*greg* Posted October 23, 2011 Share Posted October 23, 2011 second that , i use ARP bolts, there top quality stuff just make sure you use the assembly grease supplied. Quote Link to post Share on other sites
H_D Posted October 24, 2011 Share Posted October 24, 2011 if your looking to run high boost i would use arp head studs rather than arp head bolts as they alot more reliable for higher boost levels, Quote Link to post Share on other sites
Russleh Posted October 24, 2011 Share Posted October 24, 2011 are they not from a 4age though and dont fit straight into the block or head and therefor require machining. I have them and im gonna need the block drilled and the holes in the head made a fraction wider. Quote Link to post Share on other sites
