bongskag Posted October 23, 2011 Posted October 23, 2011 I have asked this question on other forums, over 200 views and no reply to the question ! all I am looking for is the seal that goes between the oil pump and the block. I have also included a picture to show what part im looking for ! please help Quote
Jamie1st Posted October 23, 2011 Posted October 23, 2011 I'm sure its just gasket sealant. No actual seal. Quote
shorty Posted October 23, 2011 Posted October 23, 2011 No there is a runner oring seal that goes around the outer edegs of the oil pump. Your best bet is toyota mate. I will try and dig put the part number as i bought a new one when i gave my egine a 10k rebuild and check up. If you go to a toyota place it will show up on the epc system but be aware there are two types of oil pump, in block and external (like yours) be sure to get the correct seal as there is a mm or two difference in the two seals. Quote
Jamie1st Posted October 23, 2011 Posted October 23, 2011 No there is a runner oring seal that goes around the outer edegs of the oil pump. Your best bet is toyota mate. I will try and dig put the part number as i bought a new one when i gave my egine a 10k rebuild and check up. If you go to a toyota place it will show up on the epc system but be aware there are two types of oil pump, in block and external (like yours) be sure to get the correct seal as there is a mm or two difference in the two seals.Thanks for clearing that up, was only about 4 months ago I built my engine and already forgot lol Quote
