A L 3 X Posted November 12, 2011 Posted November 12, 2011 On a 98 spec Glanza to the right of the low boost button on the drivers side, what are the two buttons on top of each other for, anyone got a pic?Mine has been replaced with a fog light button, tempted to get it all put back to how it should be. Quote
Lee_EP82 Posted November 12, 2011 Posted November 12, 2011 I got hazzards light switch in the middle and Rear demister on the right mate. Quote
_shaun_ Posted November 12, 2011 Posted November 12, 2011 next to me low boost i just got a blanking plate Quote
bucketep91 Posted November 12, 2011 Posted November 12, 2011 ive got a passenger seatbelt warning light in 1, hazzards and rear de mister in the others Quote
_shaun_ Posted November 12, 2011 Posted November 12, 2011 hmm not sure what bit your talking about now ha as above center bit ive got same as bucketep. then on drives side were the window controls are to the right is the high/low button then next to that is the blanking plate Quote
Guard1an Posted November 12, 2011 Posted November 12, 2011 These are only found on automatic model, iirc one is MANU and the other says POWER.They alter the rpm limit for gear change. Quote
A L 3 X Posted November 12, 2011 Author Posted November 12, 2011 Mines a 98 spec so in the centre console I have hazard on left, passenger seatbelt warning in middle and rear screen demist on right, and then have the low boost button by the mirrors, although now i've removed the restriction I might put something here...its to the right of that where the fog button is and i've seen two buttons in its place before? I dunno if pre facelifts have the boost button somewhere else?These are only found on automatic model, iirc one is MANU and the other says POWER.They alter the rpm limit for gear change.Ah yeah that would make sense it was a pic of an auto I saw it on, cheers man Quote
