dai_ep82 Posted November 15, 2011 Posted November 15, 2011 Hi ive recently fitted a 4efte inlet mani to my n/a 4efe. Im using the standard 4e throttle body. Problem im getting is that it either revs very high or they fluctuate up and down. I unplugged the white plug out of the sensor on bottom of throttle body and it now idles fine. Obviously this is not right as my engine management light has come on but has anyone got any ideas on what the problem could be. Any help would be great cheers? Quote
enzo_e492901 Posted November 15, 2011 Posted November 15, 2011 Hi ive recently fitted a 4efte inlet mani to my n/a 4efe. Im using the standard 4e throttle body. Problem im getting is that it either revs very high or they fluctuate up and down. I unplugged the white plug out of the sensor on bottom of throttle body and it now idles fine. Obviously this is not right as my engine management light has come on but has anyone got any ideas on what the problem could be. Any help would be great cheers?My guess is it's a vacuum leak.When using a FE throttle body with an FTE inlet it creates a gap at the back of the throttle body. This is because the mounting face of the FTE inlet is different to the FE one.You can get a plate made up to the shape of the FE inlet to sit between the FTE inlet and FE throttle body.Gavin Quote
dai_ep82 Posted November 15, 2011 Author Posted November 15, 2011 My guess is it's a vacuum leak.When using a FE throttle body with an FTE inlet it creates a gap at the back of the throttle body. This is because the mounting face of the FTE inlet is different to the FE one.You can get a plate made up to the shape of the FE inlet to sit between the FTE inlet and FE throttle body.GavinAh right I didn't know that, cheers for the reply. How hard is it to get the fte throttle body to work on it instead then? Quote
enzo_e492901 Posted November 15, 2011 Posted November 15, 2011 Ah right I didn't know that, cheers for the reply. How hard is it to get the fte throttle body to work on it instead then?I'm not sure to be honest. The FTE throttle body has a different throttle position sensor and cold idle/idle up system.Gavin Quote
Asad Posted November 15, 2011 Posted November 15, 2011 Mine went on a treat, no issues whatsoever with idle....did you move the throttle cable bracket over? Make sure the throttle is fully closed and not being held open by the throttle cable? throttle body gasket ok? Block off all the un-needed ports on the mani? Inc idle control valve? Quote
dai_ep82 Posted November 17, 2011 Author Posted November 17, 2011 I've now put the standard inlet back on and I'm getting the same prob, idling up and down. When I unplug what I think is idle control valve it idles normal Quote
ryan lang Posted November 17, 2011 Posted November 17, 2011 where to in south wales are you mate? i can have a look at it for you if you want? im in cwmbran Quote
dai_ep82 Posted November 17, 2011 Author Posted November 17, 2011 where to in south wales are you mate? i can have a look at it for you if you want? im in cwmbranI'm in pontypridd mate, pretty sure its a faulty idle control valve Quote
ryan lang Posted November 17, 2011 Posted November 17, 2011 yeah could be, i've got a spare n/a TB you can buy off me if you want? has a ICV on it that works Quote
dai_ep82 Posted November 17, 2011 Author Posted November 17, 2011 yeah could be, i've got a spare n/a TB you can buy off me if you want? has a ICV on it that works How much u want for it Quote
dai_ep82 Posted November 17, 2011 Author Posted November 17, 2011 £20?Would you take 15 for it ? Quote
ryan lang Posted November 17, 2011 Posted November 17, 2011 yeah suppose so, pm me for my address if your gunna come up n collect it dude i should have 2 so we can fit them n see Quote
dai_ep82 Posted November 18, 2011 Author Posted November 18, 2011 yeah suppose so, pm me for my address if your gunna come up n collect it dude i should have 2 so we can fit them n see Pm'd Quote
