Seen someone selling a complete rear axle and states it will fit for both Gt and Glanza v, It comes complete with discs and pads with the cables and braided lines.
I want to know is there any difference and will I come accross any issues for when swapping it over to my Uk ep91?
I brought a gt one for mine and all I needed was the turbo brake lines, as it came with the hand brake cables, it was a direct bolt on fit
The only thing I will say is the gt axle is deffinately narrower than a uk spec ep91 rear axle. I have heard that the glanza axle is 20mm wider than the gt axle, but I can't confirm this :lol:
All it means is you will end up having inset rear wheels but some spacers can fix that!
Yea think morgey has it pretty much spot on from memory thought it was only 10mm though unless it's 10mm each side! If you haven't already upgraded to braided lines you may aswell while your at it!
Thanks guys, yeh I will have to get some spaces then, just waiting for a reply to check if it Gt or a Glanza one. Then hopefully get it fitted in the next week
