Can running to thin oil make the engine smoke ?
Im running the engine on cheap oil atm to flush it through!
think its 5w15 or 10w15
i know i normally use 5w40 on my toyotas
or should i use Higher grades ?
what do you lot use ?
Running an oil that is too thin could cause the engine to smoke. I'd recommend something a little heavier now, given the engines are pretty old and starting to wear a little.
Kep in mind it is winter, but i'd say use a 10w 50 this should give you plenty of "headroom" for when the temps are high and still be reasonable at cold starts etc.
Always try to run a Fully Synthetic ester based oil.
