JDM Bear Posted January 2, 2012 Posted January 2, 2012 I know this question has been asked before...ALOT but im just looking for a strait answer realy-What is needed to swap the glanza engine into a na -engine,box,driveshafts annd????Is there a plug and play loom i can get from anywhere?Can i litraly put the engine in with glanza engine loom it all connect up and connect the glanza ecu and it run?Any info will be apresiated. thanks Quote
Evjatar Posted January 2, 2012 Posted January 2, 2012 I know this question has been asked before...ALOT but im just looking for a strait answer realy-What is needed to swap the glanza engine into a na -engine,box,driveshafts annd????Is there a plug and play loom i can get from anywhere?Can i litraly put the engine in with glanza engine loom it all connect up and connect the glanza ecu and it run?Any info will be apresiated. thanksYou can use the old gearbox, but you would need the right size clutch cover. Better to stick with the glanza box. You will need the loom from a glanza and cut and solder a lot, turbo engine loom has some sensors that aren't on the na-car. Loom has to be custom made. Quote
JDM Bear Posted January 2, 2012 Author Posted January 2, 2012 You can use the old gearbox, but you would need the right size clutch cover. Better to stick with the glanza box. You will need the loom from a glanza and cut and solder a lot, turbo engine loom has some sensors that aren't on the na-car. Loom has to be custom made.That was a quick reply thank you. Does anyone have a diagram of the wiring that needs to be done or anything simlar? Quote
greasemonkeyspb Posted January 2, 2012 Posted January 2, 2012 That was a quick reply thank you. Does anyone have a diagram of the wiring that needs to be done or anything simlar?toyotagtturbo.com mate look in the awfully helpful electrical sectionim almost done on my conversion its not as easy as first thought really but im using an ep82 loom etcim also using na shafts and box etc all should work ok.......you will also need a front mount kit as top mount inter cooler wont clear the bonnet like i say im halfway through this conversion too and found this out Quote
JDM Bear Posted January 2, 2012 Author Posted January 2, 2012 toyotagtturbo.com mate look in the awfully helpful electrical sectionim almost done on my conversion its not as easy as first thought really but im using an ep82 loom etcim also using na shafts and box etc all should work ok.......you will also need a front mount kit as top mount inter cooler wont clear the bonnet like i say im halfway through this conversion too and found this outCool ill have a look thanks bud. is it better to use the ep82 loom instead of the glanza loom? Im planning on puting a front mount on anyways so thats ok thanks for the heads up though bud.What id you buy just engine and ep82 loom? Quote
greasemonkeyspb Posted January 2, 2012 Posted January 2, 2012 Cool ill have a look thanks bud. is it better to use the ep82 loom instead of the glanza loom? Im planning on puting a front mount on anyways so thats ok thanks for the heads up though bud.What id you buy just engine and ep82 loom?yes mate that is helpful apparently gt loom is easier to patch in but if you use a glanza full loom and clocks may just be able to swap all wiring over complete mate as ep91 should be the same really i brought a gt complete paid a grand for it with rear end damage stripped it and put engine in my sportif yeah im looking at front mounts but ones on ebay all seem to big lol Quote
JDM Bear Posted January 2, 2012 Author Posted January 2, 2012 cool. ill start looking on the fourm you posted up. i might be pm'ing you crying soon asking for advice lol.they sell just pipes on ebay so cud get just the pipes and a small intercooler Quote
