any 1 know anything bout puttin the 5efe in a starlet, my 5efe came this mornin but the distributor has been taken off an the ignition leads were cut. are the 4efe leads and dizzy the same, also any thing i need to swap frm the 4e to the 5e. im gonna put the 4e gearbox on it so do i use the 5e or 4e flywheel an clutch? cheers
Pretty sure the dizzy will be the same. You could do with the 5E ECU,but ive heard of problems with the immobiliser. Your original ECU will work fine (so ive heard)
I dont know about the flywheel,sorry. Ill be finding out soon though,im doing this swap very soon :rolleyes:
ye im gonna run it off the same ecu, sum 1 said you gotta swap the sumps so the exhaust can go around it but then some said you dont av to. im gonna be doin the swap this saturday hopefully so if all goes well il let you know what i had to change. this dizzy better wrk lol
The flywheel is different, the clutch is the same...
I have a flywheel thats fit both 4E and 5E and it have 8 holes... one set matches the 4E and one set matches the 5E..
Im thinking about a swap with the 5EFHE (110 HK) engine, since my 4EFTE needs a rebuild...
done the swap, shes a beast. gotta wait til my bans up now though to take it for a proper rip lol. all i had to do was swap the throttle boddies because the tps is different and swap the water temp sensor because there diff connectors, everything else went straight in. im pretty sure the flywheels are the same but the clutches definately are. i used the 4e clutch wiv the 5e flywheel, it started like the engines never been out.
  • 2 weeks later...
i dunno anywhere around my area to get it rr'd but heres some pics of the swap
the old 4e
http://img48.imageshack.us/img48/2567/5exb0.jpg
the old 4e out
http://img124.imageshack.us/img124/2382/5e3sf6.jpg
http://img510.imageshack.us/img510/8905/5e4mq3.jpg
the 5e ready to go back in
http://img442.imageshack.us/img442/5812/5e5ff6.jpg
5e in, just swapin things around
http://img409.imageshack.us/img409/5462/photo003ox9.jpg
finally all up an runnin
http://img509.imageshack.us/img509/6726/photo004al5.jpg
i used the old cam cover too which says 4efe on it so u cant tell the difference with the engines by lookin at em
  • 2 years later...
I know I am reviving a very old post but here goes. Can I just change the head and block of my 4efe to a 5efe? My 4efe uses 2 coil packs instead of a distributor? Can this work or do I have a lot of other stuff to do?
