right basically im using an ep82 engine in my n/a turbo conversion however im struggling with wiring....
if i was to buy a glanza ecu both inner and engine wiring looms and clocks will it be a straight swap and away i go???
many thanks steve.
In theory yes but some sensors and plugs will differ from your gt engine. You would also need the wiper arms to I believe try asking socks he's done it this way before.
I may have a v for spares soon to so let me know if you need the looms and stuff! :D
yer theres three sensors on engine that differ.. one on throttlebody/inlet, one on thermostat area, and i think alternator? cant quite remember was a while ago that i swapped them over. correct me if im wrong.
also if yu use glanza looms you will need to use glanza stalks and modify the mounting brackets for them as the n/a and glanza ones differ slightly.
you also need to drill a hole in the bulkhead for the extra part of the glanza loom to go through.
hope that helps.
sam
You need a 1 way brake valve and the power steering pump hose is a tight fit on the n/a steering rack. Check the link below for a completed conversion.
/>http://www.ukstarletclub.com/forums/index.php?showtopic=6590
