do you need ballasts to run hids?
hey guys basically been working in my quadlight conversion all day everything was going well all lights working high beam main beam etc sidelights and indicators so i thought great job done
then i turned my lights on and nothing , so ive been running around all evenin with a multimeter and all the conections have continuity bar the hids and theres no power from the hids ( the lil black box connected to battery)
my high beam , sidelights etc still work so WTF
im thinking maybe the hids have died , so i was wondering if i use the hid bulb but cut the ends off n wire it to earth and the main beam wire on the car will it work as a normal bulb ?
Is that the transformer thing that's died? I don't think you can use them as normal because HIDs need 1000s of Volts to run which is what that transformer thingy does. Besides it won't pass MOT with HIDs now :(
