oh so the lsd doesnt help as much? its annoying like anyone that knows me knows i dont "race" but its good to get to 70mph quick but this like 1.8bmw just pulled away cause there was no traction -.-
Im due to have my car back next month, gonna be over 300bhp god knows wa thats gonna be like, only thing i can suggest is alter the boost in different gears, il only be running about .7 bar in a TD05 in second gear, nothing worse than spinning up, i used to run 1.3 bar in all gears on a ct9 hybrid, first and second where just pointless :/
this is the next question on ct9 if you were boosting 1.3 bar is that okay cause you ll be flowing less air than td04 on 1.1?
You'll be putting the turbo out of it's efficiency range, I'd suggest you run 1.1 max
LSDs are very useful, one of the best mods you can do it makes a massive difference the car just grips and grips
The heat would also effect the engine I'm sure?
Remember the throttle isnt a switch..... theres the linear bit in the middle that helps prevent wheel spin..
BUT
an LSD will help, as will suspension setup.
