Noticed this on the wife's Glanza the other day...going over bumps in the road etc a knocking sound coming from the front nearside suspension area.
Upon further investigation it's definitely in that area, if I put my weight on the top of the front wing around the suspension area it knocks each time.
Without me taking it apart what's the most likely culprit and cure to this?
Worn out top mount buy the sound of it??
You MAY be able to see if its worn buy look under the bonnet, not sure on that though
The only thing I can think of is anyother sort of suspension bushes in the lower arm or anti-roll bar
Cool...
The TRD Coilovers are being collected tomorrow from the docks ;) so when the EP82 has them on there, worse case scenario I can whip the stock fronts onto the EP91 :p
  • 3 weeks later...
Just an update on this...
whipped the front nearside strut off last night (10 minutes!) and popped the nearside strut on from the ep82....dropped it back down and hey presto, knocking gone, wife impressed :)
