yeh lift up your bonnet, and there will be a screw at the top of the indicator unit. that holds the whole unit in place
then there will be 2 screws behind the unit which should release the lense.
enjoy.
Don't be scared to use a little force, you'll see where the lense clips into place onto the actual unit, just push them up with a screwdriver then tilt it. Hope that helps.
