how easy/hard is it to remove a rocker cover?? ive got a painted n/a cover to put on my mrs car today but ive never removed a rocker cover before, the gasket is ok etc so is it jus a case of undoing the nuts and popping it off?? cheers
Yeah pretty straight forward.
Remove your plug leads and PVC valve hose, undo the 5 nuts and it should lift off.
You may need to remove you oil cap to get access to the bolt below it.
Also be aware that the PVC valve can become brittle and break easily with age
Regards
Gary
  • 10 months later...
