Gavin434 Posted February 24, 2012 Posted February 24, 2012 Hi I'm new to the forum my mate has a starlet gt ep82 with a ef 4e engine we have just replaced the engine and now it's hunting and idling about 1200rpm it miss fires a little when reving and under load way could I check I'm going to the thermostat tomorrow is there anything else ? Quote
akyakapotter Posted February 24, 2012 Posted February 24, 2012 plugs / leads / dizzy / idle control valve that should keep you busy for a bit Quote
Gavin434 Posted February 24, 2012 Author Posted February 24, 2012 Plugs/leads/dizzy have been checked I'll check the icv thanks Quote
Starbuck Posted February 24, 2012 Posted February 24, 2012 Rear inlet vacuum hoses put back in the correct place? Quote
Taggy Posted February 24, 2012 Posted February 24, 2012 Yeah like starbuck said, check all your vacume pipes on the back of the intake. Quote
Gavin434 Posted March 3, 2012 Author Posted March 3, 2012 Ave checked everything mentioned turned out to be the pipes at the back of the inlet manifold and throttle body can any body tell me excactly wat pipe goes where? Thanks Quote
