diller Posted February 29, 2012 Share Posted February 29, 2012 (edited) Hi guys, got all belts done last week and woke up to this after i started it this morning, its seems the car is hunting. I waswondering does anyone know wat might cause this as it's doing my head in........Ive put in new plugs aswell......and in low revs it nearly cuts out if im goin to take off in it.[media]http://www.youtube.com/watch?v=JXU69v-bDPE&context=C394646fADOEgsToPDskLdOSTkGslizMLgcii_TQ9UAny help appreciatedDiller Edited February 29, 2012 by diller Quote Link to post Share on other sites
Taggy Posted February 29, 2012 Share Posted February 29, 2012 Sounds like its misfiring, take all your leads off clean up the contacts with a squirt of wd40 in the ends, then take your dizzy off and clean up the contacts inside as well as the rotor arm. While your at it take your plugs out and gap them properly, if they are new they they are nearly always way to far apart.Give that a try and then let us know. Quote Link to post Share on other sites
Glanza Mac Posted February 29, 2012 Share Posted February 29, 2012 as said above ^ Quote Link to post Share on other sites
Taggy Posted February 29, 2012 Share Posted February 29, 2012 Quote Link to post Share on other sites
Flaminsam Posted February 29, 2012 Share Posted February 29, 2012 agreed with taggy. sounds like a bit of a misfire dude. Quote Link to post Share on other sites
diller Posted March 4, 2012 Author Share Posted March 4, 2012 Wel lads was with the mechanic today and he said it a fueling problem a bad mixture or something.....he checked plugs, timing belt an all seemed soundso im just wondering if my fuel pump could be on the way out????Under low revs its at its worst like doin 30-50 kph around town it could chug up the street an then on idle it runs as in video. But when i have it on the open road doin 80-100 kph it seems not to bad like.Also ive noticed i do not have this sensor in my engine bay but where it goes to on the intake is blocked off---->>>>Any help greatly appreciated Diller Quote Link to post Share on other sites
diller Posted March 4, 2012 Author Share Posted March 4, 2012 Ok guys done some homework online with the problems and this ticks all the boxes http://www.ehow.com/facts_4899182_symptoms-bad-oxygen-sensor_.html Quote Link to post Share on other sites
DavidAshton Posted March 4, 2012 Share Posted March 4, 2012 If it started happening after you got the belts done that kinda ponits to the problem!Are you certain the timing is bang on?Also you can run these cars without a lambda sensor, disconnect it and see what it does? Quote Link to post Share on other sites
diller Posted March 4, 2012 Author Share Posted March 4, 2012 On 3/4/2012 at 12:08 PM, DavidAshton said: If it started happening after you got the belts done that kinda ponits to the problem!Are you certain the timing is bang on?Also you can run these cars without a lambda sensor, disconnect it and see what it does?If i disconnect it, its quiet possible its gonna be the same as is, but yes the timing is spot on an all. i had a mechanic check timing yesterday and all he said everything seems ok and the link above points to the sensor been the problem mate Quote Link to post Share on other sites
diller Posted March 4, 2012 Author Share Posted March 4, 2012 Ive disconnected the sensor an it idles the same as when connected so im gonna try a new one in it an see if it makes a difference when Camskill delivers it Quote Link to post Share on other sites
Taggy Posted March 4, 2012 Share Posted March 4, 2012 When you had the timing belt done, did you drive it home and it was working ok without any of these faults, or has the car been running shit since the work was done? Quote Link to post Share on other sites
diller Posted March 4, 2012 Author Share Posted March 4, 2012 It was rough before i got the timing an all done mate, it was a problem previous to the belts been done.....anything to do with timing was all tested an retested again to make sure they were ok......there is a blow in the flexi aswel an im sure with the flexi been close to the decat that wouldnt help the sensor??? Quote Link to post Share on other sites
diller Posted March 5, 2012 Author Share Posted March 5, 2012 Lambda Sensor's ordered Quote Link to post Share on other sites
