awesome! cheers mate.
only other thing was when i tried bleeding the first time (top nipple) the fluid just cam out under the thread and on the caliper not through the bleed pipe?
this ever happened to you before?
You only do the top one's, the bottom one's are there so the calipers can be mounted on either side of the car.
The midilite callipers (don't know what yours are) have two piece bleed nipples as standard so the part which thread into the caliper body should be very tight and not leak then you bleed the smaller one threaded into it - also they use imperial size bolts, so a 1/4" ring spanner for the nipples will be handy.
perfect mate^^ i thought this to be the case just wanted to check as i dont wana go breaking my wilwoods some how lol.
cheers fellas. really helpful :)
