Azz Posted March 1, 2012 Posted March 1, 2012 Bit awkward to take a photo as you can't see properly but I have a leak on the left hand middle section of my engine and it spraying everywhere by hitting my alternator belt.Anyone got any ideas what it could be Quote
Ryan-11 Posted March 1, 2012 Posted March 1, 2012 could be a crankseal, turbo oil feed pipe maybe broke, sump leaking. Quote
diller Posted March 1, 2012 Posted March 1, 2012 Crank seal mine was leaking an the belt was throwing the few drops from it all over the place......but check the sump and turbo oil feed also Quote
Azz Posted March 1, 2012 Author Posted March 1, 2012 Cheers guys I can tick off oil feed but could be crank :/ I think I will do sump first tho Anyone tell me were to get all the seals from ? Quote
yaristurbo Posted March 2, 2012 Posted March 2, 2012 Toyota, I meant is it power steering fluid or engine oil Quote
Azz Posted March 2, 2012 Author Posted March 2, 2012 Toyota, I meant is it power steering fluid or engine oil Oh haha no mate my drive says it is Defenetly engine oil :/ Quote
Taggy Posted March 2, 2012 Posted March 2, 2012 It seems crank seals on these are fairly common, i think mine is weaping also, i am not looking forward to the prospect of replacing it! Quote
Azz Posted March 2, 2012 Author Posted March 2, 2012 It seems crank seals on these are fairly common, i think mine is weaping also, i am not looking forward to the prospect of replacing it!Yes mine has been leaking slighty for a while now but this last week it has got a lot worse :/ Looks like time off work next week to get it sorted ! Quote
akyakapotter Posted March 2, 2012 Posted March 2, 2012 Think mine is going on the gear box end :-( not looking forward to getting / doing it as the seal is £50 plus from Toyota Quote
Azz Posted March 2, 2012 Author Posted March 2, 2012 Think mine is going on the gear box end :-( not looking forward to getting / doing it as the seal is £50 plus from Toyota£50 :0 for a seal !!! That's ridiculous Quote
Azz Posted March 3, 2012 Author Posted March 3, 2012 Cab anyone tell me if the standard crank pulley has 4e on one half and 5e on the other ?? Quote
turbo Grant Posted March 4, 2012 Posted March 4, 2012 Not sure what you mean. The pulleys are interchangeable. Quote
Azz Posted March 4, 2012 Author Posted March 4, 2012 Not sure what you mean. The pulleys are interchangeable.Well I have been stripping my engine down this week and finding little bits that ar'nt standard then cam across my top cam pulley and git puzzled as it says 5E on one side of it so I'm trying to find out weather it is standard or not Quote
turbo Grant Posted March 4, 2012 Posted March 4, 2012 The top cam pulley will have 4e and 5e on it. They all have it. Quote
Azz Posted March 4, 2012 Author Posted March 4, 2012 The top cam pulley will have 4e and 5e on it. They all have it.Cheers matey put my mind to rest Quote
