PhilGT93 Posted March 8, 2012 Posted March 8, 2012 right having bad trouble with the gt starting then yesterday wouldnt start at all,did a compression test today..... and verry poor1- 1002-1253-754-75any ideas what could be causing this ideas would be verry much appreciated Quote
Whitegv Posted March 8, 2012 Posted March 8, 2012 Water in oil? Heaters don't work? Overheated? Could be headgasket/ cracked headpiston rings another possibility. Quote
PhilGT93 Posted March 8, 2012 Author Posted March 8, 2012 no water in oil, heaters work fine, never over heated,thinking valve seats may be Quote
Flaminsam Posted March 8, 2012 Posted March 8, 2012 check the timing marks dude. you could have possibly jumped a tooth on the belt. if not then a cylinder leakage test is needed. could be rings or anything. Quote
PhilGT93 Posted March 8, 2012 Author Posted March 8, 2012 might have to bud ill let you know soon Quote
micky boy Posted March 8, 2012 Posted March 8, 2012 check the timing marks dude. you could have possibly jumped a tooth on the belt. if not then a cylinder leakage test is needed. could be rings or anything.x2 Quote
PhilGT93 Posted March 9, 2012 Author Posted March 9, 2012 right bit of a development with it , got it going agen after towing it off wared it up to running temp and it fires back up no problem sooo..... went to it this morning first turn it fired, ran it for 5 mins switched it off and left it till dinner......................... went to start it and it wont go agen :/ but has a really strong petrol smellany ideas to that one? Quote
Taggy Posted March 9, 2012 Posted March 9, 2012 oh another thing, do a compression test with it warmed up properly, you will get odd/incorrect results if you do it from cold as your piston rings will expand slightly when hot.If your still getting results below 150psi a cylinder then it could be worn rings, you can check to see if the rings are worn by pouring a teaspoon of oil down each cylinder, crank it over over again with the tester and see what you get. If it shoots up loads then your rings are worn,if its still low then it will point to other things such as the head/vales etc.Good luck! Quote
PhilGT93 Posted March 9, 2012 Author Posted March 9, 2012 throttle fully open mate and im going to do a hot test tommorow if i can get it going agen Quote
Flaminsam Posted March 9, 2012 Posted March 9, 2012 just out of interest do you have a fuel pressure regualtor on your car? check that the two bolts for the adapter in the fuel rail havnt come loose. also as taggy says do the compression test hot. and the teaspoon of oil trick to try and raise compression by sealing the piston better in the bore. Quote
PhilGT93 Posted March 9, 2012 Author Posted March 9, 2012 no engines still standard ill check the bolts and try agen and keep updated mateand i did the oil thing with the cold test got one of the 75's up to just under 100 but still wouldnt fire have tto a hot one tommorow Quote
