as title says, could someone please enlighten me as to what the difference is between running an emb and an emu? hoping to get an emanage shortly and was just wanting to know what the benefits are, if any, of choosing one over the other.
Emu has launch control, emb doesn't. Thought it had antilag but think you would need a stand alone ecu for that. Racetech are doing a stand alone ecu with both systems.
Edited by daniel_g
im running emu...
and yes it has launch control, but as far as im aware there is no antilag feature....
in terms of tuning i belive you can add and take away fuel on the emu,
on the emb you just add fuel.... best bet is speak to nick jones at tuning developments he can explain tad better
The emanage blue cannot remove fuel directly/efficiently even with changing afr table values.
Emanage Ultimate can ;)
I run one and can't recommend it enough.
Joz
