jimmymac101 Posted March 10, 2012 Posted March 10, 2012 I seem to have developed a flat spot in 3rd gear and in 4th sometimes but its only when i put my foot down, im stumped to what could be causing it! I have a standard air box, well completely standard engine at 113k just had cat back system fitted though hopefully someone can shed some light on what could be causing this. Quote
Amjad Posted March 10, 2012 Posted March 10, 2012 I noticed mine being a bit slower today, think it's just the hot weather! Quote
jimmymac101 Posted March 10, 2012 Author Posted March 10, 2012 I.don't think its that I just took her for a spin and I have flat spots in 2nd 3rd 4th and 5th Quote
jimmymac101 Posted March 13, 2012 Author Posted March 13, 2012 Plugs and leads are ok I had a slightly sticky throttle cable but sorting it made no difference Quote
jimmymac101 Posted March 13, 2012 Author Posted March 13, 2012 how would i check these things? Its very annoying I go to over take and its like a massive pause in the engine and then suddenly catches up. if I put my foot down at 2k will go to 3-4k and then drop down and then will catch up to the revs it should be at. Quote
jimmymac101 Posted March 13, 2012 Author Posted March 13, 2012 corolla inlet mani and standard throttle body standard exhaust mani Quote
5T4R7ET N/A Posted March 13, 2012 Posted March 13, 2012 put a vid up mate, sounds like clutch slip they way its being described. Quote
jimmymac101 Posted March 13, 2012 Author Posted March 13, 2012 I will try at some point if I can I can be going along in 3rd decide to put my foot down and it would still do it :/ Quote
Asad Posted March 13, 2012 Posted March 13, 2012 Have you tightend the throttle cable properly on the corolla manifold? getting full pedal movement in sync with the throttle body butterfly? Quote
jimmymac101 Posted March 13, 2012 Author Posted March 13, 2012 I wouldn't have a clue asad its been on there since I brought the car almost a year ago and I never had this problem before Quote
