Turbo Goose Posted March 21, 2012 Posted March 21, 2012 Hi people,Probs been covered a few times but can't find a post.Just wondering whats required to fit glanza brakes to an N/A?And does anyone know the dimensions of SR brake discs as I ordered some normal N/A ones but didn't fit Quote
rob_bower Posted March 21, 2012 Posted March 21, 2012 all you need is the carriers and discs everything else is the same! i want to say the standard sr brakes are 238x18 but i might be wrong Quote
morgey Posted March 21, 2012 Posted March 21, 2012 Yep sr brakes are 238x18 but some people insist they came with the larger 256x18. Mine didnt but when I ordered a set of n/a brakes I got sent the bigger ones :/ Quote
Turbo Goose Posted March 21, 2012 Author Posted March 21, 2012 I ordered some which were apparently the correct size but the 'depth' of them was too much so caught on the guard at the back so would have needed spacers to fit them.rob, do you mean the carrier that the caliper fixes to? Quote
rob_bower Posted March 21, 2012 Posted March 21, 2012 yes just the bit that bolst to the hub and the caliper either from a gt or glanza infact i might have some from a gt in the garage.arent the 256mm ones off a paseo? Quote
Turbo Goose Posted March 21, 2012 Author Posted March 21, 2012 Do you know the height the discs should be for the SR?Because I got some before that were 238 diameter, 18 thickness, but the height was wrong.The height being the overall thickness Quote
