5ecolin Posted March 23, 2012 Share Posted March 23, 2012 well lads i just got a cynos and want to turbo it i already have the low comp. 5e motor but i dont know wich loom to use i have a ep82 mines ecu that i want to use is the ep82 loom plug and play ?and from the ignition system is it just the igniter coilpak i nead or is there more that i neadif u know of somthing i missed please tell me thanks colin Quote Link to post Share on other sites
EPilot Posted April 21, 2012 Share Posted April 21, 2012 Hallo,I turboed an FHE in an EP82 and that was fine,used the standard loom and ecu just changed a couple of sensors cus the plugs were different,changed the sump,pickup and oil filter housing and injectors for 4E-FTE items,u'll have to drill and tap the block for the filter housing locating bolts or get a filter relocation kit which is much better,if you use the EP82 ecu and loom you will loose the AICS function so better to go for 4E-FTE inlet manifold,yes you will need the 82 distributor and coil,standard ported ex manifold for meantime with CT9 and blitz cast de-cat will see you happy and crack free,I might be wrong but the EP82 loom won't integrate into your Cynos,I imagine a Galanza loom will fit directly to the fuse boxes etc,depending on yr,anyone else know?? Quote Link to post Share on other sites
