akyakapotter Posted March 29, 2012 Posted March 29, 2012 Hello everyone just dropped the miss’s home. When I started the car sounded like the something was knocking when I put the clutch pedal down it stopped. Am I right in thinking this is the release bearing on its way out?? If it is that I may as well replace clutch and the crank shaft oil seal as its weeping oil while it’s all out. How hard of a job is this to do what parts would I need to replace and dose anybody have part numbers thanks in advance nick. Quote
Flaminsam Posted March 29, 2012 Posted March 29, 2012 sounds like it nick. most glanzas and gt's do it after a while. i wouldnt worry too much though, but if your after doing crank seals any way then it may be worth changing it. i had a complete engine with box and loom out in around an hour so a box will maybe take a hour and half as there are more bolts etc to undo. ive got charls (funny onion) clutch to change soon. Quote
akyakapotter Posted March 29, 2012 Author Posted March 29, 2012 best get on the hunt for clutch kit and all the seals i need. Do you no if the rear crank seal on tuning devlopnets is the right one. As its a dam site cheaper than Camskills and Toyota. Quote
akyakapotter Posted March 30, 2012 Author Posted March 30, 2012 Anybody useing this clutch kit ? CLICKY Quote
pick1 Posted March 30, 2012 Posted March 30, 2012 (edited) Give mike a bell at tuning developments mate he will point you in the rite direction and answer any questions you have mate Edited March 31, 2012 by pick1 Quote
akyakapotter Posted March 30, 2012 Author Posted March 30, 2012 been talking with nick from there just wanted to no if anybody is rocking one Quote
