SG_EP91 Posted March 29, 2012 Posted March 29, 2012 As title states whe i push on my accelerator you can feel it kind of stick after a quarter of the way down, not that you have to shove it or put pressure on it to push it but just feels a wee bit sticky if anyone gets my drift? Can be noticed when car in neutral and go t push accelerator and just feel a slight stick!Anyone know if there anything i could try make it smooth or anything? Quote
Shahzad Posted March 30, 2012 Posted March 30, 2012 I have the same problem since i changed to a corolla manifold. I think the best long term solution is to get a new throttle cable. In the mean time i put abit of wd40 down the cable Quote
akyakapotter Posted March 30, 2012 Posted March 30, 2012 bit of engine oil down it would most probly do the trick Quote
WallaceGlanza Posted March 30, 2012 Posted March 30, 2012 Check it at the inlet manifold and lube it up there too if it's sticky at that point. Quote
