You need to adjust it on you actuator coming off the turbo, its a threaded bar going into a housing with a spring in it.
Edited by Jamie1st
you need to slacken that 8mm nut off then pull the arm off the waste gate lever then twist the arm of the actuator anticlockwise 2threads mate then put the arm back on the lever and put the c clip back on and nip up the 8mm bud that should do it
first things first, what actuator do you have? standard or HKS? standard cant be adjusted it has to be upgraded
ahhh right, 1 sec ill find you the correct informationss
/>https://home.comcast.net/~ronald_miranda/hksactuator.pdf
Take the standard one off, lie it on the floor and with the hks one wind the arm so as that it is the same length as your standard one or maybe slightly longer then it should prevent your over boosting problem :) job done
  • 3 weeks later...
I know its 15days late but you dont want to be guessing it really you want to find out the correct lengths and measuring it, otherwise you could do some damage.
