RossTRD Posted April 18, 2012 Posted April 18, 2012 I have an ep82 gt do I look to connect this to the ecu or does this wire need to go somewhere under the bonnet? Quote
turbo Grant Posted April 18, 2012 Posted April 18, 2012 Is it a propper wide band afr gauge. If its just a rich lean type then it's not worth fitting. You want a afr kit that comes with a 5 wire sensor Quote
RossTRD Posted April 18, 2012 Author Posted April 18, 2012 Just lean rich still wanna fit it tho just wanna know the best way to wire the sensor Quote
turbo Grant Posted April 18, 2012 Posted April 18, 2012 Need to wire your up to the O2 sensor. Can tap into the wire going to the ecu but it will not read any good for tuning a car. They are only for show Quote
Jamie1st Posted April 18, 2012 Posted April 18, 2012 Definatly want a wide band on there instead of the narrow band. Quote
Asad Posted April 18, 2012 Posted April 18, 2012 as above mate, wouldnt waste your time/money on fitting it....wideband is where its at Quote
