rinseep82 Posted April 20, 2012 Posted April 20, 2012 (edited) does anyone know the torque settings for arp headbolts?? i kno standard headbolt but aint arp different??also the longer ones go on the inlet side dont they its been a while since iev done them lolcheers chaps Edited April 20, 2012 by rinseep82 Quote
DevonGT Posted April 20, 2012 Posted April 20, 2012 I thought the settings would've come with the bolts?But try this - http://arpinstructions.com/?src=arp-bolts Quote
Idrees Posted April 20, 2012 Posted April 20, 2012 From memory it's 3 stages; 20, 40 and 60ft/lb. Definitely double check though, and as mentioned there should be a paper included in the box.Edit - just checked, and yes it is 3 stages to 60ft/lb. Quote
rinseep82 Posted April 20, 2012 Author Posted April 20, 2012 (edited) Cheers chaps I'll get it done tomorrow last time I did it tho I did standard ones to oem specs and one snapped luckily I was able to get it out don't want this happening again is there a reason for this something I did wrong?? Edited April 20, 2012 by rinseep82 Quote
rinseep82 Posted April 20, 2012 Author Posted April 20, 2012 22nm then 44nm but after a did it to 22 and then worked up to 44 it felt like it wasn't getting any tighter then click snapped?? Quote
Idrees Posted April 20, 2012 Posted April 20, 2012 Were the heatbolts brand new? They should be torque'd to 44 in two stages as you mentioned, then a 90 degree turn iirc. Quote
rinseep82 Posted April 20, 2012 Author Posted April 20, 2012 Yea mate they were new dunno y it happend just sempt like it wasn't getting any tighter so torque them to 60ft/lb then a 90 degree turn Quote
shorty Posted May 7, 2012 Posted May 7, 2012 I know its old but update so ots acurate for searched info.Is no 90° turn just three equal stages upto 60ft/lb. if you want to be mega anal then recheck tourque afyer 10 heat cycles. i.e warm up-cool down is 1 cycle. Quote
shorty Posted May 7, 2012 Posted May 7, 2012 Lol cheers for reiterating iddy ;) is missunderstood by many unfortunatley. Quote
rinseep82 Posted May 7, 2012 Author Posted May 7, 2012 The 90 degree is after you have reached the desired tourqe after you have reached the top tourqe level you put a degree wheel on your wrench and give them all a 90 degree turn Quote
shorty Posted May 8, 2012 Posted May 8, 2012 Except on ARP!!! No90° turn dude just stop at 60ft/lb. Like i say can recheck torque after 10cycles if you wish. but no 90° degree turn is used with an arp bolt/stud set! Quote
rinseep82 Posted May 8, 2012 Author Posted May 8, 2012 yea mate i forgot to mention the oem part in my last post iev tourqued my head down with arp bolts to 60ftl/bs and all is well went like a dream Quote
