Who has had this done, were from, and for how much?
I'm looking to get my NA done, the wheels are sitting way too far in the arches but it's too low to slap spacers on alone :(
Thanks
Amjad
Thanks, Archenemy in Hampshire have quoted me £130-150 to roll the lip on all arches, how is that for a price?
I ideally wanted them rolled and flared..hmm
  • 2 weeks later...
The front there is nothing you can do unless you remove the arch liner then you can bend the tabs that hold it up out the way.
Rear can be done but to do the rear well you need to mod the rear bumper mount by trimming it down as much as possible.
Arch enemy were saying they could refit the arch lining with some kind of sealant
Georgie on here had the rears done okay I think
Dude, book them for rolling. When the chap turns up and gets going query if you could have them flared also cash in hand....
..I don't aplaud this kind of thing and never done such - for those concerned! :thumbsup:
i had mine done by arch enemy a week ago dude, did a good job :) rears were no problem but on the front there isn't much of a lip he could roll back so just rolled the tabs and kinda did what he could with the rest :)
Im constantly picking rubber off my back drivers side tyre :( its getting really really bad. and quite a bit of rubber too, noticable on the tyre as well. is that just a panhard rod though?
How do you mean? Check to make sure its not rubbing on anything! Doesn't sound like a panhard rod issue, that just aligns the rear wheels :)
You'd need a panhard to fix it Dave yeah
Matty would you say it's worth getting done then on an EP? Has it given you a fair bit of clearance? As I'd like to get some 15mm hubcentric spacers on
yeh i would mate, i reckon its given at least another inch on the rear to mess around with bud :)
plus if your only going with 15mm it will be fine :)
