Aloha amigos.
Wondering if any of you guys could help me out with a quick question.
Visually, the inlet manifolds for the Starlet (EP91 non turbo) and the Paseo, look identical.
Question is though, is the inlet actually indentical on both cars?
Cheers in advance :p
Aloha amigos.
the inlet mani is the same just different throttle bodies
pretty sure theyre identical. same bore and everything. inlet mani's are identical.
you do you ask mate?
Cheers guys.
Am asking as have the original mani from my Starlet from when I changed it to a corolla manifold.
And though shall put it to use, and paint it, then do a like for swap, providing it is the same mani as what's already in the Seo, which appears to be te case.
(trying to make my engine bay look nice :p ) :p
Not sure on gains, PM Glanza179 as he fitted one to his Seo, so he should be able to tell you.
However, don't think that much improvement can be had tbh.
