Blitz Posted April 29, 2012 Posted April 29, 2012 are glanza and starlet gear boxes the same? just wondering? Quote
Idrees Posted April 29, 2012 Posted April 29, 2012 A Glanza is a Starlet! Do you mean non-turbo? Quote
Socks Posted April 29, 2012 Posted April 29, 2012 All the gearbox's are the same yes..However..The ratios vary as well as some have LSD's some dont! Quote
Blitz Posted April 29, 2012 Author Posted April 29, 2012 is that the differance then socks so a glanza gearbox would have the same ratio be the same as a non turbo gearbox? what do you do cause your car eats gearboxes doesnt it? Quote
mattyD Posted April 29, 2012 Posted April 29, 2012 The diff inside also varies between mk1 gt's & n/a's and the later gt's/ glanza's in that the bolt count is 6 instead of 8 so if you come to fit a quaife in an early gt box you might run into difficulty Quote
Socks Posted April 29, 2012 Posted April 29, 2012 The diff inside also varies between mk1 gt's & n/a's and the later gt's/ glanza's in that the bolt count is 6 instead of 8 so if you come to fit a quaife in an early gt box you might run into difficultydidnt know this!Blitz na i said there the same design, but the ratios are different! Quote
mattyD Posted April 29, 2012 Posted April 29, 2012 Lol, I know through experience mate What a bastard it was Quote
AdamB Posted April 29, 2012 Posted April 29, 2012 True, the early gt's had a 6 bolt diff and the glanza has a slightly different gear ratio's to aid in accelerating because it's heavier than the gt. Quote
