Weyro Posted May 21, 2012 Posted May 21, 2012 Going to do a compression test on the Glanza V. What pressure should it be achieving on each piston? Cheers Quote
Starbuck Posted May 21, 2012 Posted May 21, 2012 it will vary fella. But a reading of around 150-160 across all 4 and you're in the right area of good. Quote
Socks Posted May 21, 2012 Posted May 21, 2012 If engine was up to running temp ^^Generally your not looking at the amount of pressure...Your looking at differences between the cylinders! Quote
Weyro Posted May 21, 2012 Author Posted May 21, 2012 OK cool, hopefully all is well. Just doing a health check Quote
Flaminsam Posted May 22, 2012 Posted May 22, 2012 There should be no more than a bar difference across all 4 cylinders. I did one on mine and got around 150-160psi across all 4. Quote
