Stefan_s Posted May 24, 2012 Posted May 24, 2012 hi, i think my actuator is faulty but notsure, when i accelerate it fells pretty laggy and theres a hissing noise that i thought was a leaky dumpvalve but replaced it with a hks ssqv and its still the same, i was told the actuator wasnt working by someone, anyone have any advice? thanks Stefan Quote
A L 3 X Posted May 25, 2012 Posted May 25, 2012 I had the same when I bought mine, you'd see it boost up and then as the revs increased the boost would start to drop on the gauge and you could hear a strange noise. I replaced mine with a HKS actuator as it was on my to do list anyway Quote
Stefan_s Posted May 25, 2012 Author Posted May 25, 2012 well its when i accelerate the boost isnt going up as fast on the gauge as it used to and theres the weird hissing noise and it just dosnt feel as fast Quote
A L 3 X Posted May 25, 2012 Posted May 25, 2012 May just be a boost leak or could be actuator I suppose, I assume the problem with mine is it was weak and wasn't holding the boost in the high revs? Quote
Driver Posted May 25, 2012 Posted May 25, 2012 Sounds like a boost leak more then anything else. Pressurise your boost hoses and listen when engines turned off (can do it with a compressor and abit of inginuity(SP))Other then that, replace actuator and try again, there only £5/10 second hand or throw a HKS on if your staying CT9 Quote
Stefan_s Posted May 25, 2012 Author Posted May 25, 2012 thanks for the advice, its going to my mates garage tomorow so he can check everything and picking up a hks actuator for £20 so should get it sorted soon Quote
