Removing my aircon - Already used a smaller belt...
Fitting civic rad
FMIC - Purchased cold pipe pipe and will be runing no BOV
Manifold
Braided oil feed
De-cat/Screamer
Relocating air filter
So far ive got all the gaskets sorted for everything im doing...
Bit unsure as to when removing the aircon what to do with the wires and bridge what plugs? and what does bridging mean :fool:
What do I do with the Silicone vacum hose which goes into the efi pipe and standard bov? Just blank them?
Hi mate with the air con you need to bridge the pressure switch which is on the right hand side of the bar i just used a split pin and then put insulating tape round it. failing doing this keeps the cooling fan to run all the time.
Edited by GT Phayer
if you need a hand with it all i can come down and sort you out mate? send half of my life working on these things loll
