i'm considering buying a td04 starlet off a trader, he said to me that it had a standard ct9 and now they put a td04 in it, but as they just swapped it over, the boost need setting up correctly .
can somone expain what this means .. does it sound dodgey
ps. sorry for my grammar but keyboad battries nearly dead
Edited by Max9650
just got another reply from him... he said ... new turbo fitted running at 0.6 would need the apexi neo setting up correctly , is this correct cause it has a fcd so i thought you could just turn it up to 1bar and ideally get a new ecu
The neo will need setting up as its a furl controller. at 1 bar you will get around 210-220. And it doesnt sound dodgey. The fcd allows the neow to control fuel above the preset oem fuel cut. a walbro pump is around 70 quid iirc. and by all meas set the boost to a bar and not set up the neo but id estimate you will blow your engine in less than a week lol.
In short its all there bar the pump to run a bar but you must have the neo set up for it to boost 1bar also a neo set up is far cheaper than a remap on an ecu.
Roughly 100quid or so at a guess for set up and i wouldnt panic. i was td04 @.6 for aaaaaagggges and ragged the tits out of it. oem fuel cut is .8 on the small ct9 so .6 on the td04 shud fuel ok till very high revs where it will prob lean out ever so slightly. the oem ecu overfuels a fairbit when more air flows so .6 should cuase no damage dude.
Neo is litraly a fuel level controller. but more acurate than a rrfpr and fcd alone. hks actuator will alow for more boost though just gotta wind the actuator arm on it. As for walbro fit it yourself bud ait hard tbh just fookin stinks the car out with fuel for a bit lol.
