hey guys my overhaul kit came today from speedvision for my rebuild..box came open i dont know if part's are missing
also i dont know what some of these parts are if anybody could name some..also would be good for future reference for people (1 and 19 are the same)
1. Stem oil seals
2. N/a mani to exhaust section gasket / ring
3. Rocker cover washers for on top
4. Rubbers for the injectors, you get one below and on top per injector
5. Injector o rings, you got an extra one
6. Crush washers for fuel line banjo
7.
8. Exhaust gasket for n/a
9.
10.
11.
12.dizzy cap ring seals - one possibly for the water pump pipe at the back that has a ring on it about that size so the other larger rubber may be for the dizzy as i dont know what size the second one is.
13. dizzy cap ring seals - one possibly for the water pump pipe at the back that has a ring on it about that size so the other larger rubber may be for the dizzy as i dont know what size the second one is.
14.Oil pickup to block seal??
15. oil pump ring.
16. Bottom timing belt cover seal
17.inlet gasket
18.manifold gasket
19. Valve stem seals, exhaust and intake are different
20.spark plug seals
21 Intake cam seal belt end
22.cambelt side crank seal
23.clutch side crank seal
24.rocker cover gasket
25.head gasket
26.timing belt cover seal(upper)
Edited by Mo3
Number 4:Rubbers for the injectors, you get one below and on top per injector
Edited by Taggy
2. N/a mani to exhaust section gasket / ring thing lol.
12 and 13 look like dizzy cap ring seals. one possibly for the water pump pipe at the back that has a ring on it about that size so the other larger rubber may be for the dizzy as i dont know what size the second one is.
15. oil pump ring.
if 14 is made of rubber i cant tell it may be the small rubber ring for the bottom of your oil pickup. could also be 10 tho.
Its pretty obvious the kit is generic for possibly all 4EFE engines, so there may be a few extra bits in there for other models variations of the engine. Looks like you have everything you need to rebuild an engine, apart from head bolts.
thanks for helping out guys nearly there!
ye i got them as well, did not add to pic and will be using cometic 1.4mm heaed gasket instead of OEM one
pretty sure number 10 is for the big bolt that holds the oil filter housing on, number 11 a copper washer? if so i would say its for the turbo oil feed (oil filter housing side) but there should b 2
  • 3 weeks later...
