Mo3 Posted June 1, 2012 Share Posted June 1, 2012 (edited) hey guys my overhaul kit came today from speedvision for my rebuild..box came open i dont know if part's are missingalso i dont know what some of these parts are if anybody could name some..also would be good for future reference for people (1 and 19 are the same)1. Stem oil seals2. N/a mani to exhaust section gasket / ring3. Rocker cover washers for on top4. Rubbers for the injectors, you get one below and on top per injector5. Injector o rings, you got an extra one6. Crush washers for fuel line banjo7.8. Exhaust gasket for n/a9.10.11.12.dizzy cap ring seals - one possibly for the water pump pipe at the back that has a ring on it about that size so the other larger rubber may be for the dizzy as i dont know what size the second one is.13. dizzy cap ring seals - one possibly for the water pump pipe at the back that has a ring on it about that size so the other larger rubber may be for the dizzy as i dont know what size the second one is.14.Oil pickup to block seal??15. oil pump ring.16. Bottom timing belt cover seal17.inlet gasket18.manifold gasket19. Valve stem seals, exhaust and intake are different20.spark plug seals21 Intake cam seal belt end22.cambelt side crank seal23.clutch side crank seal24.rocker cover gasket25.head gasket26.timing belt cover seal(upper) Edited June 2, 2012 by Mo3 Quote Link to post Share on other sites
Socks Posted June 1, 2012 Share Posted June 1, 2012 25 headgasket24 rocker cover gasket18 exhaust mani gasket17 inlet manifold gasket1 stem oil seals3 rocker cover nut washers20 spark plug hole gaskets Quote Link to post Share on other sites
Taggy Posted June 1, 2012 Share Posted June 1, 2012 (edited) Number 4:Rubbers for the injectors, you get one below and on top per injector Edited June 1, 2012 by Taggy Quote Link to post Share on other sites
Russleh Posted June 1, 2012 Share Posted June 1, 2012 2. N/a mani to exhaust section gasket / ring thing lol. 12 and 13 look like dizzy cap ring seals. one possibly for the water pump pipe at the back that has a ring on it about that size so the other larger rubber may be for the dizzy as i dont know what size the second one is. 15. oil pump ring. if 14 is made of rubber i cant tell it may be the small rubber ring for the bottom of your oil pickup. could also be 10 tho. Quote Link to post Share on other sites
Mo3 Posted June 2, 2012 Author Share Posted June 2, 2012 5. Injector o rings, you got an extra one6. Crush washers for fuel line banjo8. Exhaust gasket for n/a16. Bottom timing belt cover seal19. Valve stem seals, exhaust and intake are different21 Intake cam seal belt endIts pretty obvious the kit is generic for possibly all 4EFE engines, so there may be a few extra bits in there for other models variations of the engine. Looks like you have everything you need to rebuild an engine, apart from head bolts.thanks for helping out guys nearly there!ye i got them as well, did not add to pic and will be using cometic 1.4mm heaed gasket instead of OEM one Quote Link to post Share on other sites
kingo228 Posted June 5, 2012 Share Posted June 5, 2012 The stem seals are different colours , what colour goes on what valve stem??thanks Quote Link to post Share on other sites
melon Posted June 5, 2012 Share Posted June 5, 2012 exhaust brownintake is silver Quote Link to post Share on other sites
Ryan-11 Posted June 5, 2012 Share Posted June 5, 2012 pretty sure number 10 is for the big bolt that holds the oil filter housing on, number 11 a copper washer? if so i would say its for the turbo oil feed (oil filter housing side) but there should b 2 Quote Link to post Share on other sites
Mo3 Posted June 27, 2012 Author Share Posted June 27, 2012 hmm i did it today...did exhaust brown and intake silver Quote Link to post Share on other sites
