I'm getting a vf34 turbo kit with external waste gate with a 14psi spring in it but I'd be wanting to run at least 1.5 bar but is it better to use just a stronger spring or use an apexi avcr boost controller to adjust it ? Which is a better idea ? Thanks
U want a spring pretty close to the boost u want to run mate, im going to run a 1 bar spring but run 1.4 bar through my AVCR, apparently its harder to control with the boost controller if your running a spring way off your highest boost setting, i wanted a lower pressured spring so i could run low boost in first and second but now il have to run atleast 1 bar, i was told this by Mike at TD :-)
Well i suppose it would be cheaper to just use a spring if u always wanted to run 1.5 bar mate, boost controllers are good if u want different settings etc, im not sure though if they also help with boost creep so maybe it will help you over boosting past 1.5 bar, im not 100% on that though.....
You can use a boost controller to help spooling a turbo by the gain feature. I would stick a 1 bar spring in as you can always switch a boost controller off and back down to 1 bar :)
Tbh I'm not bothered by a hi and low kinda idea I'd just Hav 1.5 bar permanent I don't like goin slow , it's my car for fun n fast not borin haha , so if I had a1.5 bar spring with no boost controller u think it may creep ?
Im not 100% mate as my car is also being built so ive been asking questions like yourself, my civic turbo is just running a wastegate spring though and it does feel like im getting boost creep, i dont have a boost gauge in her lol
Id keep the avcr mate there good bits of kit :-) and i only bought it as a run around until my glanza is forged so not spending no money on her lol
If your funds will allow it mate run the avcr and your spring so your chances of boost creep is as low as possible
