Removing standard boost solenoid
Hey there if you clear all ecu faults then unplug it and drive it for few mile then check your fault codes. If no fault codes show then shouldnt be a prob, maybe even recheck it at later date again to be sure. I take it your using some other boost control?
  • 1 month later...
I had a ct9a and it creeped allot. Installed a hks actuator and it didnt creep anymore. maybe cause the harder spring inside and its adjustible for more boost then .8 bar
now having a Blitz hybrid ct9 with a HKS actuator, on my Blitz ebc there are 2 modes to adjust the actuator to operate.
Manual
Auto
if i put it on manual and choose to let it spool up as quick as it can you got full boost before the 3k BUT then it creeps! Even to 1,64 bar for once. knowing this isnt good for the engine so used the auto boost function and set it to 1,2 bb. Spools up slower from low rpm. but spoolup is the same from about 3k or above.
