kingo228 Posted June 20, 2012 Posted June 20, 2012 ^^ penzzoil 5w40 fully synokay to use in a 4efteThanksDave Quote
kingo228 Posted June 20, 2012 Author Posted June 20, 2012 its a freash build , new bearings , pistons , piston rings , gaskets ect, all replacememt toyota parts. (ACL bearings)need a oil to use on run in - suggestions pleasebut 5w40 fully syn will be alright to use once run in ? got 600liter sitting at work so would be idea if i can use it Quote
Starlet__SR Posted June 20, 2012 Posted June 20, 2012 Best thing to do is speak to Opie Oils, they're brilliant when it comes to oil advice and sales. 5w40 should be fine once run in.Day Quote
starletburkie Posted June 20, 2012 Posted June 20, 2012 use a cheap mineral oil and change offen when running in Quote
Asad Posted June 20, 2012 Posted June 20, 2012 this ^throw a hard drive magnet or something of the sort in the sump to catch anything/everything then after its run in remove it....oh and take pics of it lolcant remember but its fusch titan 5w40 or 5w30 opie reccommend for the EP`s Quote
Flaminsam Posted June 20, 2012 Posted June 20, 2012 Yup use mineral oil. It will protect the engine during running in. And once the engine is run in don't use fully synthetic. These engines are not designed to use it. Semi synth is more than adequate. The fully synthetic has less protective qualities than semi synth. And is also quite thin. Quote
mech5107 Posted June 20, 2012 Posted June 20, 2012 I run Eneos full synthetic 5-40 in my 2etelu with 230.000klm. Changing every 7000klms the oil consumption is around 500ml...but the turbo is also started to burn some oil... Quote
Flaminsam Posted June 20, 2012 Posted June 20, 2012 Mech does your car use 500ml per month or every oil change? I've used semi synthetic in all my engines and not had a problem. Quote
Flaminsam Posted June 20, 2012 Posted June 20, 2012 Ah cool. Sounds like you have a healthy engine Quote
Jamie1st Posted June 20, 2012 Posted June 20, 2012 Millers Competition Running in Oil, then after run in process I run 5w40 Fully Synth Titan Pro Race S, this is what Tuning Developments use aswell I believe. Quote
kingo228 Posted June 20, 2012 Author Posted June 20, 2012 alright il get a few gallons on mineral oil for run in , normal running semi or full thow :@ haha Quote
