beej Posted June 24, 2012 Share Posted June 24, 2012 (edited) Warning - Removing The Template Below or Not Filling Out All The Sections Will Prevent Your Advert From Being Approved!Item Condition: UsedPrice & Conditions: £SOLDItem Description: 4efte engine, 70k with proof, run perfectly, only removed from my glanza due to fitting an upgraded internals one,Pictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £100Item Description: glanza gearbox, came with the engine i bought, unneededPictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £40Item Description: standard starlet steels with virtually brand new tyres, full set of 4, two are at homePictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £SOLDItem Description: speedvision hybrid ct9, pulled 186bhp @ tuning developments, blows a puff of blue smoke out after boosting, was rebuilt a couple of months ago at a cost of £550 with a receipt, but now they wont admit it has a fault, they say its been tested and theres no faults, i replaced the turbo and it cured smoked so i guess it needs the oil seals replacingPictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £SOLDItem Description: ct9 - clocked, no play in shaft, oil in exhaust side, untestedPictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £60Item Description: decat pipe, i gave this a quick spray over, i dont mind spraying it properly with vht black i have at workPictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £SOLDItem Description: nightpager screamer, i believe these are over 300 new, very good conditionPictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £SOLDItem Description: nice aluminium oil capPictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £50Item Description: ecu, 4efte, ep91, wont fit ep82Pictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £10Item Description: alternator, came on new enginePictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £10Item Description: starter, came on new engine/gearboxPictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £20Item Description: td04 actuator, came on td04, unneeded as im running external wastegatePictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £SOLDItem Description: glanza inlet, came on new enginePictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £SOLDItem Description: hks actuatorPictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________Item Condition: UsedPrice & Conditions: £10Item Description: standard glanza fuel pump, replaced with walbroPictures:Location: Stoke-on-Trent ST9Contact Details: 07854631791 or bradleytjenkins@googlemail.com______________________________________________________________anything else you can see in pictures you need, hoses, bolts etc you can have within reason Edited July 10, 2012 by beej Quote Link to post Share on other sites
samc1992 Posted June 24, 2012 Share Posted June 24, 2012 Would you sell the oil breather plastic 90 degree connector on top of block ? Quote Link to post Share on other sites
Hawwy Posted June 24, 2012 Share Posted June 24, 2012 Td 04 acuator come with bracket? Whats standard boost on it? And does it suit a rotated td04 if it has bracket with it that is Quote Link to post Share on other sites
beej Posted June 24, 2012 Author Share Posted June 24, 2012 Td 04 acuator come with bracket? Whats standard boost on it? And does it suit a rotated td04 if it has bracket with it that isit comes with the bracket, hard to see but its sitting on the inlet mani in pic, it comes with the bracket but i doubt it will work on a rotated turbo, standard actuator from a 55plate wrx impreza, i dont know what spring they use thoughWould you sell the oil breather plastic 90 degree connector on top of block ?yeah can do, you need the seal too? Quote Link to post Share on other sites
samc1992 Posted June 26, 2012 Share Posted June 26, 2012 Yeah I'll have seal aswell how much you after ? Quote Link to post Share on other sites
beej Posted June 26, 2012 Author Share Posted June 26, 2012 Couple of quid for postage mostly, 5 posted? Quote Link to post Share on other sites
leemillin Posted June 26, 2012 Share Posted June 26, 2012 (edited) I'll have the inlet if its 4 a turbo Edited June 26, 2012 by leemillin Quote Link to post Share on other sites
nest Posted June 26, 2012 Share Posted June 26, 2012 ill have that oil cap off you mate pm me details Quote Link to post Share on other sites
Whitenoize Posted June 27, 2012 Share Posted June 27, 2012 I will take one of those ct9 mate how much with postage?? Quote Link to post Share on other sites
StarletMad Posted June 27, 2012 Share Posted June 27, 2012 Il take the hybrid turbo and hks act off u friday if thats ok? Quote Link to post Share on other sites
mork Posted June 27, 2012 Share Posted June 27, 2012 I'll take the dry Glanza CT9 mate. Are you going to Japfest2 by any chance? If not, PM me Paypal details and cost inc. postage. Quote Link to post Share on other sites
beej Posted June 27, 2012 Author Share Posted June 27, 2012 I'll have the inlet if its 4 a turboyeah its a glanza one, pm meill have that oil cap off you mate pm me details ok no worries, ill do it nowI will take one of those ct9 mate how much with postage?? couple of quid postage? 13 ok?Il take the hybrid turbo and hks act off u friday if thats ok? the hybrid is now sold sorry, and hks is prov. sold, ill let you know on fridayI'll take the dry Glanza CT9 mate. Are you going to Japfest2 by any chance? If not, PM me Paypal details and cost inc. postage.not going mate, got no pennies couple of quid for postage, 13 ok? ill pm details now Quote Link to post Share on other sites
beej Posted June 30, 2012 Author Share Posted June 30, 2012 offers on whatevers left now, just want them out the wayengine prov sold Quote Link to post Share on other sites
