4efte engine, fte gearbox, hybrid ct9, decat, screamer + more-stoke on trent
Warning - Removing The Template Below or Not Filling Out All The Sections Will Prevent Your Advert From Being Approved!
Item Condition: Used
Price & Conditions: £SOLD
Item Description: 4efte engine, 70k with proof, run perfectly, only removed from my glanza due to fitting an upgraded internals one,
Contact Details: 07854631791 or bradleytjenkins@googlemail.com
______________________________________________________________
Price & Conditions: £100
Item Description: glanza gearbox, came with the engine i bought, unneeded
Price & Conditions: £40
Item Description: standard starlet steels with virtually brand new tyres, full set of 4, two are at home
Item Description: speedvision hybrid ct9, pulled 186bhp @ tuning developments, blows a puff of blue smoke out after boosting, was rebuilt a couple of months ago at a cost of £550 with a receipt, but now they wont admit it has a fault, they say its been tested and theres no faults, i replaced the turbo and it cured smoked so i guess it needs the oil seals replacing
Item Description: ct9 - clocked, no play in shaft, oil in exhaust side, untested
Price & Conditions: £60
Item Description: decat pipe, i gave this a quick spray over, i dont mind spraying it properly with vht black i have at work
Item Description: nightpager screamer, i believe these are over 300 new, very good condition
Item Description: nice aluminium oil cap
Price & Conditions: £50
Item Description: ecu, 4efte, ep91, wont fit ep82
Item Description: alternator, came on new engine
Item Description: starter, came on new engine/gearbox
Price & Conditions: £20
Item Description: td04 actuator, came on td04, unneeded as im running external wastegate
Item Description: glanza inlet, came on new engine
Item Description: hks actuator
Item Description: standard glanza fuel pump, replaced with walbro
anything else you can see in pictures you need, hoses, bolts etc you can have within reason
Edited by beej
Td 04 acuator come with bracket? Whats standard boost on it? And does it suit a rotated td04 if it has bracket with it that is
it comes with the bracket, hard to see but its sitting on the inlet mani in pic, it comes with the bracket but i doubt it will work on a rotated turbo, standard actuator from a 55plate wrx impreza, i dont know what spring they use though
Would you sell the oil breather plastic 90 degree connector on top of block ?
yeah can do, you need the seal too?
I'll have the inlet if its 4 a turbo
yeah its a glanza one, pm me
ill have that oil cap off you mate pm me details
ok no worries, ill do it now
I will take one of those ct9 mate how much with postage??
couple of quid postage? 13 ok?
Il take the hybrid turbo and hks act off u friday if thats ok?
the hybrid is now sold sorry, and hks is prov. sold, ill let you know on friday
I'll take the dry Glanza CT9 mate. Are you going to Japfest2 by any chance? If not, PM me Paypal details and cost inc. postage.
not going mate, got no pennies :( couple of quid for postage, 13 ok? ill pm details now
