Ok so I've been having a play with my AFR's have a wide band and rrfpr so it's all good I can see what's going on my question is i cant get it anywhere near 10's on boost all I seem to be getting is some where in the 12's it's curently sent at about 3.5bar of pressure on the rrfpr cheers nick
Edited by akyakapotter
Hey yea it was discussed quite a lot on the topic of afr.
Most people came to the conclusion that on idle it should be near 14.7 and on wide open throttle 12.2 or less was ideal. Preferably around 11-10 afr.
That's what was decided any who. After a lot of research its not only afr that a tuner looks at. Its exhaust gas temp, ignition timing and alsorts. Best stick to 11-10 on full boost/wide open throttle for now.
