I have recently bought a fidanza light weight flywheel and its fitted in my 6 speed box along with exedy clutch that I previously had, since fitting the new flywheel i get vibrations 4500rpm and above, clutch etc is not marked or damaged before and after installation
So my question is
Does it need balancing? But it's a new flywheel or do I need a different clutch?
Or is it something else?
And has anyone else had a similar experience ? As being light weight does it not absorb the vibrations as the standard flywheel if you get what I mean?
Please help guys
Edited by Raffa_MK
Might have something to do with where the clutch and flywheel meet? As its a used clutch the surface won't be as smooth as the flywheel possibly causing the vibrations..........I dno :s lol
Well the flywheel has been checked but It's within tolerance of the manufacture so thinks its down to clutch plate, will soon find out when it's replaced
