A L 3 X Posted July 10, 2012 Posted July 10, 2012 Anybody got a guide showing how to stop the airbag light coming on with an aftermarket wheel? I believe it's with the use of some kind of resistor? Quote
Nanglebadger Posted July 11, 2012 Posted July 11, 2012 or just pull the bulb out mate, thats what i did.Phil. Quote
A L 3 X Posted July 11, 2012 Author Posted July 11, 2012 I want it to work as it should with the light coming on when ignition is first turned on if possible, especially with new not rules and such? Quote
Socks Posted July 11, 2012 Posted July 11, 2012 Check my last update in my build thread http://www.dashlightremoval.co.uk/Got mine from here^ Came with instructions, very simple tbh tho, just plug this thing into the connector, job done! Quote
A L 3 X Posted July 11, 2012 Author Posted July 11, 2012 Just ordered one mate thanks a lot Just seen them silicone bungs on your thread also, which vac ports can I remove when myAir cons out? Quote
Socks Posted July 11, 2012 Posted July 11, 2012 The bigger one on top of inlet next to TB and I hjave a racespec rocker cover so I bunged the PCV valve too! Quote
A L 3 X Posted July 11, 2012 Author Posted July 11, 2012 Ah I see mate, so can IRemove all those brown and black blocks Wat the pipes go to? Quote
