_shaun_ Posted July 11, 2012 Posted July 11, 2012 looking for some advise on a few things i want to spray my car myself i will be going for a pearl white now ive only ever rattle canned a few things before would it be idiotic to try spray a whole car?few other things am wondering is1.i want to delete the hole for the antenna and the door bump strip groves whats the best way to do this? i assume weld a plate for the antenna but for the bump strips am not 100% sure ive been told just filler but that seems like a hell of alot of filler when ive always been under the impression u should use as little as possible. when it comes to the paint work i no taking out all the windows is ideal but since i live in the middle of nowhere it would cost an absolute bomb to get a windscreen company to come out and remove the window is this realy needed?2.my understanding of pearl is u get the whole car perfect lay down the primer ( few coats) then flat than down then lay down a base colour ( few coats) then flat that then lay down the pearl till your happy with it do u then flat it again and and clear it? 3.ill be borrowing a mates compressor so i plan to get a set of guns ( one for primer one for the rest) but is there any air powered tools i could get to make my life easier that dont cost a fortune?4.spray the whole car any idea how many litres of paint ill need making sure i have extra for any mistakes i makeany help be greatcheers shaun Quote
bowdengtturbo Posted July 11, 2012 Posted July 11, 2012 I want too do the exact same thing with my ep82 let me know how u get on cheers Quote
StuDoc 72 Posted July 11, 2012 Posted July 11, 2012 Cant help with the door grooves mate but you can paint a car by just masking everything up its the way most inexpensive jobs are done obv its best to remove as many parts as possible but the windscreen and other windows can be masked would be good to remove door windows and the rubber seals. Quote
Hawwy Posted July 11, 2012 Posted July 11, 2012 Id leave rub strips as they are , if you can mask windows good then itl be fine mate Quote
bowdengtturbo Posted July 12, 2012 Posted July 12, 2012 Yeah i was gunna remove quarter panel windows and mask up im not too worried about door grooves as it staying the same color Quote
_shaun_ Posted July 12, 2012 Author Posted July 12, 2012 realy want the door strips gone but ill just need to wait and see the whole car should be just striped to a bare shell and ill be doing the engine bay a different colour it seems easy todo when your talking about it watch when i start it ill just be on here in a bad moan complaining about what an idoit i am for starting it found a few shades i like going to order some samples and see what its like out in the sun Quote
StuDoc 72 Posted July 12, 2012 Posted July 12, 2012 Shaun white wise mate you want either VW white as its the whitest white or to be diff go for fords new white thats kinda greyish blue aswell possiby the nicest colour on the market. Quote
_shaun_ Posted July 12, 2012 Author Posted July 12, 2012 i was looking at a candy white with a silver pearl or possibly aslight blue but cant decided if it might be tacky hard to tell looking online only way is to get a sample in the light Quote
StuDoc 72 Posted July 12, 2012 Posted July 12, 2012 See the more intricate you go with the paint the harder it will be for you to lay down. I can probly get paint codes for you. Have you seen any of these fords with this new colour? Quote
StuDoc 72 Posted July 12, 2012 Posted July 12, 2012 Looks even better in the flesh but its white with like a grey/blue tint from it looks fuckin epic manhttp://www.autotrader.co.uk/classified/advert/201228478349612/sort/default/usedcars/engine-size-cars/2l_to_2-5l/colour/white/fuel-type/petrol/maximum-age/up_to_2_years_old/model/focus/make/ford/onesearchad/used/onesearchad/nearlynew/onesearchad/new/page/1/postcode/g821rq/radius/1500?logcode=p Quote
_shaun_ Posted July 12, 2012 Author Posted July 12, 2012 yea looks not bad in pic hmm choices choices Quote
Ryan-11 Posted July 12, 2012 Posted July 12, 2012 The bump strips on the door i would say fill them, can see any easier way of doing it, they wont need too much filler.The windows come out pretty easy with some cheese wire, there easy enough to put back in too, but like others are say u can just mask the windows up and take the door windows out.Pearls and candy paint are alot harder to work with so im told, (im just a panel beater not a painter)make sure u get a water trap for the compressor, u dont want water dripping onto your paint, also get urself a dual action sander, its alot easier than rubbing down by hand, dont rush the job, make sure everything is perfect before u start painting, the key to a good paint job is the prep work. Quote
_shaun_ Posted July 12, 2012 Author Posted July 12, 2012 yea the prep work is going to be the hard part me thinks once thats done a little practise with paintgun and i think ill be fine. am in to rush to get it done so ill have plenty of time to get it exactly how i want Quote
StuDoc 72 Posted July 13, 2012 Posted July 13, 2012 If you paint yours and it turns out good shaun am comin up to repaint mine haha!! Quote
