At what point do the standard fuel pump and plug leads become a liability. Im asking this as I have most of the part i need to start upping the power on my car i just do not have these 2 of yet. Ill be running a ct9 hybrid and an arc top mount with all the usual supporting mods hopefully around 220bhp.
1. Does a walbro fuel pump just swap straight over or is there wiring required?
2. What mm leads should i have and what ones are best?
3. What heat range of plugs should i go for also?
no kinda set figures driver ran like 260bhp on stock fuel pump. but obv if u upgrade it its always a benefit. the leads its probaly better just to upgrade them as the leads u have are likely to be a good couple years old anyway.
1. straight swap u just cut 2 wires and connect the 2 wires from the pump then attempt not to shit urself as u turn the key over for the first time :p
2. magnacores are the kinda main name ull see with leads but realy any uprated ones will be dam better than the oem ones
think its heat range 8 for plugs am using atm but not 100%
i told mine last night after spending almost a grand on engine parts i only had another 3k worth of bits to buy till the engine was done then just the turbo kit/bodywork/engine management left todo :D lucky i told her via text while she was at work lol
