Hawwy Posted July 16, 2012 Posted July 16, 2012 Where are bolts located for removing glanza bumper? And how many bolts are there. Cheers Quote
fremyjay Posted July 16, 2012 Posted July 16, 2012 2 bolts under plastic covers in wheel arch, two plastic clips either side of number plate in corner of bumper to show two more and clips at top holding grill on and two under neath bumper located in middle. someone may have a picture as would be easier for you Quote
Hawwy Posted July 16, 2012 Author Posted July 16, 2012 So i have to take wheel arches off , what about the bolts on the side when looking at engine bay there 2 bolt i think on both sidesSo basically theres 2 bolts under wheel archesAnd the ones at bottom yeah?What type of clips are the onece i open bolts itl just slide off? Quote
fremyjay Posted July 16, 2012 Posted July 16, 2012 the plastics under your arches just pull back where the bumper meets and your see them no need to remove the actual arches mate, the two at the top join on slam panel, the two in the middle are hidden behind plastic caps and the three on the bottom join on bottom of chassis Quote
